Re: Farmall M shuts it's self off !!!!!!!
Posted by Roger on October 24, 2000 at 19:19:38 from (209.224.36.10):
In Reply to: Farmall M shuts it's self off !!!!!!! posted by Ken Overfelt on October 23, 2000 at 16:22:59:
Ken,
I just had a similar problem with my Farmall MD. I would start it and after it ran on gas for a few minutes it would die like the switch was shut off. I checked the carb, fuel flow, cutoff switch when switching from gas to diesel, but in the end it was the ignition switch. When I check the switch it always worked, but when the tractor was running it vibrated the switch and eventually the switch would loose it's contact. I finally discovered it by shutting off the switch and turning it on as the tractor was quitting. A new switch fixed it. Roger
Post A Followup
: Re: Re: Farmall M shuts it's self off !!!!!!!
