Sounds like a valve stuck open for whatever reason on that one cylinder.
Broken spring atc. The amount of oil shown seeping is not serious, possibly a worn guide, that would also cause it to stick. If it were a damaged piston you would hear the air exchange into the crankcase on the compression stroke.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
