Re: B missing under load
Posted by PretendFarmer on November 26, 2012 at 18:22:19 from (108.227.198.61):
In Reply to: B missing under load posted by Matt E. on November 26, 2012 at 08:15:32:
I know you did the valves BUT, you might want to take the valve cover off and make sure everything is working properly. Run it with the cover off. Its easy to do.
When my A ran like you describe, I had a couple push rods that fell off because the rocker arm assembly wasnt bolted down properly.
