Re: MD Filter Follow-up Question
Posted by hattrick on November 27, 2012 at 10:52:48 from (216.57.221.66):
In Reply to: Re: MD Filter Follow-up Question posted by rustred on November 27, 2012 at 10:37:24:
third party image
The final filter is definitely different as it has a neck on the bottom of the filter that fits down inside the machined hole. This filter is a WIX33148 and similar to the IH one that I bought. There are some people that say that you can use this filter for both but on the unit I have the hole is not the same size and not machined. I have read that on the 400's and WD/TD's that the later ones had two machined holes and used the same filter. Also there is no spring that holds the filter down. If I had the retainer/flanges it would really not be an issue. Anyone have suggestions for good Farmall Parts Yards that would have MD/TD6 parts?
