I have a extra base that takes the same filters in both if interested in going that way. Probably needs some clean up. Yes you find the early type that someone put the filters in, but unless they used the adapter the fluid is bypassing at the bottom. IH started using the same filter type bases during 400 production.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
