Farmall Tractors Discussion Board
Re: Farmall H Clutch Shaft
Posted by mjdelaney on January 14, 1999 at 06:02:18:
In Reply to: Farmall H Clutch Shaft posted by Tire Kicker on January 13, 1999 at 19:43:23:
The key thing is adjustment. There should be
7/8-1 1/8" of play between the transmission casting and point of engagement. The manual suggests this leaves about 3/16 " clearance for the release bearing.
Post a Followup
: Re: Re: Farmall H Clutch Shaft
