Quoting Removed, click Modern View to see Not to mention the value of a Super C wide front end.
As far as the damaged block goes, I would not put big bucks into doing a rebuild on it. However, if you can re-ring it and stick in whatever crank bearing inserts it needs, you can likely put it back together and get quite a lot of use out of it. Just go gently on torquing the head down, use smaller torque increments and make more passes with the torque wrench. We had an A that looked about the same (except the crack went through one of the stud holes!). We used it for years. Somebody may still be using it.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
