Re: Farmall H generator will not charge
Posted by Bob M on November 28, 2012 at 13:41:40 from (69.207.86.27):
In Reply to: Re: Farmall H generator will not charge posted by Darwindo on November 28, 2012 at 13:09:10:
Your test shows the ammeter is wired correctly and is working!
A couple possibilities for the "no charge" condition:
1 - A bad ground at the VR. Try running a wire from the regulator base to the grounded battery post. Check also also the ground jumper between the VR box and the sub-base is still intact.
2 - Loose/slipping generator belt. Check and tighten as required.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
