Re: ih cub stalls
Posted by Markbo on October 25, 2000 at 08:42:52 from (38.158.169.130):
In Reply to: ih cub stalls posted by bill on October 23, 2000 at 16:04:59:
My father-in-law has done quite extensive work on a friend's C. I also have another acquaintance that has a cub that just dies in third gear. My father-in-law suggested that this stalling under moderate load could be the result of a messed up governor. He said the C that he had worked on ran fine until you turned the mower on then it died. The governor was the culprit. Good luck!
Post A Followup
: Re: Re: ih cub stalls
