the C113 and C123 blocks are notorious for cracking in that area and in that fashion. I cannot tell you how many I have found with that crack.....and most were running just fine from a head gasket perspective. remember, these are thermosyphon engines, and there is little to no pressure in the water jacket.
These are low rpm, low compression, and relatively low "stress" engines. I have seen using one with that crack go both ways, but more often than not, I see them work fine. head gasket, rings, and bearings are not a huge investment if you are doing the work.
Bottom line, that tractor is worth every bit of $1000, in merely parts alone. C113/C123 blocks are not uncommon with the hydraulic pump opening.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
