Re: B-450 Thoughts
Posted by MJ in the UK on November 30, 2012 at 03:01:33 from (213.122.234.84):
In Reply to: B-450 Thoughts posted by frazier2cyl on November 29, 2012 at 11:51:10:
The B450 tractor was built by IH at Doncaster here in the UK from 1958 to 1970. It used a glowplug started indirect injection diesel engine of 264 cu in same size as a SM. 5 speed transmission with no TA or indipendent PTO option but fitted with a diff lock. Hydrulic lift unit mounted on top of the rear axle with cat 2 linkage and live pump on engine. They were build as a standard tractor and a Farmall rowcrop tractor. Done a lot of work on one of these tractors baling hay and straw with a UK built B55W wire tying baler. A good hard working tractor but not very handy for getting on and off. MJ
