Re: 6 volt gen w/12 volt reg
Posted by pete 23 on November 30, 2012 at 10:55:52 from (74.32.238.2):
In Reply to: 6 volt gen w/12 volt reg posted by GP Hansen on November 29, 2012 at 17:32:47:
The voltage required will send too much current through the fields which in turn have to pass through the voltage regulator points and the points will be very short lived. Actually had first hand experience with this. Sold a new 706 gas tractor to a customer. Shortly the red amp light was blinking. Checked it out, regulator was bad. Replaced regulator, worked but voltage was not nice and steady. Pulled cover off regulator and points were arcing badly. Pulled generator,(mind you I am doing this in the machine shed out on his farm, took gen back to shop. Checked it out and determined it had high rate of current draw through field coils. Further testing confirmed it had six volt field coils. Replaced with new 12 volts field coils, problem solved.
