Re: belly pump, seal replacement
Posted by pete 23 on November 30, 2012 at 11:01:25 from (74.32.238.2):
In Reply to: belly pump, seal replacement posted by 47farmallM on November 29, 2012 at 16:24:19:
Don't overlook the groove where seal runs on
coupler, like said, may need speedy sleeve or new
coupler nut. Also, they have either a bushing or
needle bearing depending on vintage and they
definately wear out. If shaft is loose seal will
not hold. To get coupler off, I usually try a few
good wacks in counter clockwise direction with
hammer and brass drift. If that does not work I just
pull them apart and clamp gears in vise. Not unusual
to find good reason inside for taking them apart.
