Re: 1206 PTO linkage adjustment
Posted by mazemeister on November 30, 2012 at 14:21:45 from (24.187.98.163):
In Reply to: 1206 PTO linkage adjustment posted by oldtanker on November 30, 2012 at 12:51:28:
you need a 0-600 psi pressure gauge on the test port. i think it's 40 psi or so when you first feel the spring and 240 or 260 at full engagement. don't quote me on the numbers though.
does it turn under power all the time? if it just drifts your brake pads are worn.
