Posted by Gary730 on December 01, 2012 at 16:41:33 from (98.70.218.85):
The transmission in my super-a has a noise like a worn out roller bearing on the end of the input shaft. I disassembled the transmission, replaced all four roller bearings, they all look bad so I thought I solved the problem. Oh no, after a total tractor re-build, including all new bearings, seals, sandblast, epoxy primed, and acrylic painted, the trans. Still has the same noise. The noise is very loud and seems to be coming from the front area of the transmission, but I’m not sure. In first gear in whines a little, second is a little louder, and third gear is loud, and forth gear is very loud. It doesn’t make any noise in neutral or reverse. When the clutch is pushed in the noise stops. Coasting in any gear with the clutch pushed in the noise stops. Both transmission shafts looked great the gears look ok for having 60 plus years of service. What did I miss?
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
