Re: Oily Brake bands
Posted by Janicholson on December 01, 2012 at 17:16:14 from (96.24.99.126):
In Reply to: Re: Oily Brake bands posted by David G on December 01, 2012 at 17:08:03:
They will start on fire, but that is not the intent. it is to heat them and drive the oils out, and turn what is remaining into carbon. Do not let them flame sensationally! some is inevitable. But the flame should be such that the band goes out when the torch flame is removed (or reduces to managable intensity and dwindles) overheating is not acceptable. Jim
