Re: 504 IHC combine
Posted by David Saville on October 25, 2000 at 17:30:39 from (142.165.110.230):
In Reply to: 504 IHC combine posted by Jack on October 24, 2000 at 19:16:30:
I assume you mean 503 combine as I don't know of a 504 (which doesn't mean it does not exist). A 503 gas combine had a 282 engine in it. My book shows a 263 in the 606 which is the same family just smaller. The 282 in a 503 did not have sleeves while a 282 in a 560 did. There will be other things to change ie the 503 has the hydraulic pump mounted to the engine you may or may not have to change the front timing cover. As far as the problem with bell housing there is a bell housing adapter plate that bolts the block so you can maybe use the one from the tractor on the engine. My main concern is why would you want to go from diesel to gas?
Post A Followup
: Re: Re: 504 IHC combine
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
