Re: Installing SM Pressure Plate Question?
Posted by D Slater on December 02, 2012 at 13:47:39 from (184.15.16.54):
In Reply to: Re: Installing SM Pressure Plate Question? posted by pete_5959 on December 02, 2012 at 13:06:13:
If the flywheel was cut and not the step, putting washers under the pressure plate would make it worse. Suspect you have a case of the clutch wouldn't release right and someone stuck the washers in hoping to help. Step height 1.406 inches.
