Go to the Nebraska tests and look at the drawbar bull as compared to the drawbar HP... there seems to be no direct correlation. I believe the pull weight means more than the Hp rating. I imagine the pull weight takes into consideration the weight, gear ratios and maybe other things. Ford tractors were geared pretty high and with a 4 speed, ratios were spread more. IH Ms and Hs had a 5 speed, JD B, A and Gs and Olivers had 6 speeds ... these things all entered into how they pulled, as well as the torque rating.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
