Re: which coil-electronic ignition
Posted by Janicholson on December 02, 2012 at 20:52:43 from (96.24.99.126):
In Reply to: which coil-electronic ignition posted by Bryce Andreasen on December 02, 2012 at 20:35:40:
The issue is a coil that matches the voltage. A 2 ohm coil should work. a 1.5 will work but draw a lot of current.
Read the directions well. If it is 12 volt, a 3 ohm coil is more like it. I think something else is wrong, timing, or firing order or something.
Was the reluctor (over the cam) set to the correct distance from the sensor. Was there a ballast resistor in the circuit that was left in, and supposed to be removed? was the bushing in the distributor OK, less -- than .001 runout? Check the directions. Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
