Re: Carb problems still....
Posted by MisterT on December 03, 2012 at 17:40:40 from (216.248.71.226):
In Reply to: Carb problems still.... posted by longear on December 03, 2012 at 17:29:57:
Seth Roemer said: (quoted from post at 02:29:57 12/04/12) Ok.. I have the h that floods and wont start. I tried seating the float needle, I cleaned it again as well. Put on the tractor turned the gas on and let it set for a hour. Tried to start it and gas runs out the bottom. Now what???
Was gas running out BEFORE you tried to start it? Did you CHOKE it? If you choked it, right there is your problem. Farmall Hs do not LIKE to be choked, and in most cases it is necessary to use that choke only AFTER the engine is running and then probably no more than about 1/2 choke. Just enough to keep it running.
Oh, and for what it's worth, "seating" that needle valve just might require you to buy a new needle and seat. "Seating" is not needed, and should NEVER be done.
This post was edited by MisterT at 17:43:12 12/03/12.
