The pic shows the sizes. from the views you show your slots might allow a slightly larger dimension on the .750 number, possibly .760" to .765" if put into the slots and can work through neutral, I would do it. I found the pic from Neblink, but I don't know who took it. The trans looks a bit rusty. as such the detent balls and springs can rust, stick, or fail. Using a space heater to warm the trans for a day or two (safely!!!!!) might reduce the moisture, Changing the fluid might be a good idea as well. 85W140 gl4 or gl5 is fine. 85-90 is also good. The loose rim on the clamps do not often reveal obvious problems. They also often need to be loosened, lubed, and retightened due to stuck threads. Jim
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
