Re: Carb problems still....
Posted by jim_uny on December 04, 2012 at 04:19:41 from (24.213.206.167):
In Reply to: Carb problems still.... posted by Seth Roemer on December 03, 2012 at 17:29:57:
with carb off gently blow in gas intake tube and make sure viton tip seals. also make sure float is not rubbing against sides. also adjust float from tang not bending tabs. this affects rubbing. start with new float if necesseary
