Re: 300 rear main seal?
Posted by David G on December 04, 2012 at 05:55:18 from (205.215.206.18):
In Reply to: 300 rear main seal? posted by Altmodisch on December 04, 2012 at 05:20:59:
You may just want to hold off if money is an issue. It is very easy to add $$$$ once you tear something apart.
I would agree with the others and replace the transmission input seal and clutch while it is apart. Splitting those tractors without stands is dangerous. The front gets real top heavy when you unbolt it.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
