Re: SC Ignition Switch
Posted by wayne in mn on December 04, 2012 at 08:47:57 from (64.118.12.213):
In Reply to: SC Ignition Switch posted by Bud W on December 04, 2012 at 08:14:41:
ASSUMING THIS IS A BATTERY IGNITION: Do you have voltage to the switch? If so, then pulling out the knob should allow voltage to exit the switch. If there is voltage at both terminals then follow the wire to the coil.
IF THIS TRACTOR HAS BEEN CONVERTED TO 12 VOLTS: Check for a resistor that has failed between the switch & coil.
