Re: grill surround
Posted by Lmack on December 04, 2012 at 15:15:33 from (24.131.58.167):
In Reply to: grill surround posted by oldiron29 on December 04, 2012 at 03:54:01:
Old, you know some of us do not know but it probably will. If I were in your shoes I would check the part numbers for both. If the same then your answer is yes.
