1)remove air intake from carb.. while someone cranks the engine, hold your hand over the carb and feel for suction. if no suction, check muffler, etc for mouse nest.
2)give the carb a sniff of ether to see if it will hit or not.
i have had one instance when engine would not hit on ether until, i believe, i drained gas tank and put in fresh gas. ??????? go figure
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
