Posted by Janicholson on December 04, 2012 at 19:28:54 from (67.72.98.45):
In Reply to: Re: 3 cyl vs 4 cyl? posted by joshua rod on December 04, 2012 at 19:18:14:
Typically the newer the tractor the higher the rpm. It is free displacement in the sense that it pumps more air, and makes resulting power. The wear factor is not important, it is usually not twice the RPM. Jim
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
