Re: farmall bn won't start.
Posted by El Toro on December 05, 2012 at 04:11:05 from (108.3.143.30):
In Reply to: farmall bn won't start. posted by will K on December 04, 2012 at 16:57:26:
Hold you hand over the throat of the carburetor while a helper makes an attempt to start the engine. See if there's good suction on your hand
if there's poor suction that indicates low intake manifold vacuum. Could have a vacuum leak between the intake manifold and engine block. I would also do a compression check and write down the readings. Hal
