Posted by mkirsch on December 05, 2012 at 06:17:09 from (64.80.110.74):
In Reply to: Splitting Farmall H posted by Matt Ki on December 04, 2012 at 17:54:29:
The front bolster bolts will NOT hold the engine in.
It also must be supported from the rear. Once you remove all the bolts between the engine and bell housing, there is NOTHING holding the engine and frame rails together.
You need to stick at least one bolt in through the frame rail and rear engine mounting plate on each side to hold things together as you slide the tractor apart.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
