424 low oil pressure
Posted by Jim Beggs on December 05, 2012 at 14:03:51 from (98.192.141.221):
Have an old IH 424. Didn't have a working oil pressure gauge for at least 20 yrs. Started having steam coming out of the oil filler pipe. Was a leaking sleeve seal. Replaced the sleeves with pistons, main and rod bearings from below. Replaced cylinder head and gasket from above. Ran great without any problems except, I put a new oil pressure and temp gauge and there is very little oil pressure--like it doesn't really read any once it's warmed up. So I replaced the oil pump with a new one. No difference at all. Runs fine and I've run it pretty hard. I'm just concerned that it has no oil pressure.
Any ideas on a solution?
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
