Re: Farmall 706, any problems?
Posted by caseyc on December 05, 2012 at 14:44:59 from (75.102.189.131):
In Reply to: Farmall 706, any problems? posted by BigTone on December 05, 2012 at 13:00:28:
The only real problem in my eyes is that you have to travel through low between high and reverse. A popular fix is updating the shifting to a 56 series (which would be the same as a 66 series too) where high is still "up", low is "down" and reverse is over and "down". With the exception of the pattern, they are all very close in operation and share many similar parts. They are actually quite easy to fix if you take your time and have any mechanical aptitude.
Casey in SD
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
