Posted by Dave_Id on December 05, 2012 at 15:48:15 from (107.207.72.252):
In Reply to: Re: 3 cyl vs 4 cyl? posted by gene bender on December 05, 2012 at 06:32:08:
My MH 253 is a 3 cylinder diesel, 4 wheel drive and was tested at 47 hp at the pto. It has 153 cu.in. At 152 cu. in. the Farmall H gets close to 28 hp on the belt. The Massey is far better than the old H. My Massey Ferguson will even outpull my M any day of the weeks. No contest.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
