Progress on H
Posted by David G on December 05, 2012 at 16:46:50 from (205.215.206.18):
I got both axles back on with new seals and gaskets, center disks are mounted again.
I pulled the brake/clutch shaft out tonight to change those seals.
I bought new bushings for the brake pins, those are next on the list. How do you guys get those out if transmission is buttoned up?
