Re: farmall 400 706 ta question
Posted by Janicholson on December 05, 2012 at 18:17:55 from (67.72.98.45):
In Reply to: farmall 400 706 ta question posted by jim_uny on December 05, 2012 at 17:53:16:
The 706 and other large frame IH have hydraulic operated TA systems. The direct clutch is as a multi plate hydraulic lockup unit where the smaller TA is a dry single plate mechanical clutch with Pressure plate and throwout bearing. The TA, in reduction, drives through a one way clutch that provides primary torque reaction control. A lockup hydraulic clutch provides some additional resistance to backwards turning of the TA spool, but also provides lockup against freewheeling and allows throttle based deceleration control (not however to be used to slow by pulling into TA from high speeds to slow down). Jim
