Re: Farmall 706, any problems?
Posted by DeltaRed on December 05, 2012 at 18:31:21 from (67.6.219.50):
In Reply to: Farmall 706, any problems? posted by BigTone on December 05, 2012 at 13:00:28:
706s are good tractors.My hi-hour(10,000) tractor got hard to shift.Rather than 'rebuild',I converted it to 56 series shifters.It shifts like that 1066 you mentioned.It wasn't hard at all.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
