I would not take it apart any further. Clean it up with solvent, and paint remover, then look carefully for wear grooves that would prevent seals from working. The flange that is adjustable should spin off. if not heat it with a propane torch and cool it then heat and cool. Driving it around with a brass drift tight then loose then tight till it begins to move will work. I like PB blaster, ATF also works. Wire brushing befor attempts at movement will assure it has clean threads to move into. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
