Re: Farmall 706, any problems?
Posted by Old-F20 on December 05, 2012 at 19:31:30 from (71.7.101.5):
In Reply to: Farmall 706, any problems? posted by BigTone on December 05, 2012 at 13:00:28:
its this crazy little thing called MAINTENENCE!!!! you need to keep the linkages adjusted properly. many people simply dont do this and then whe it doesnt shift ride or get hung up they cuss it and say thay're junk.
I have the factory shifter setup on my 806. keep it adjusted, works like a top
i dont see the big hub bub about shifting into reverse. last time i checked, i stop before backing up...........
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
