Re: Farmall 460 pulling tractor front end
Posted by IaGary on December 06, 2012 at 05:02:04 from (108.160.228.103):
In Reply to: Farmall 460 pulling tractor front end posted by chestervillefarms on December 06, 2012 at 04:52:14:
Guess I would start with a factory wide front and unless I needed to shead more weight I would use the factory wide front.
I have seen to many home made fronts fail in pulls.
If you don"t want the factory front to pivot just block it at the frame to reduce pivot.
Gary
