That is some serious damage. Unfortunately, it was used by someone that didn't know the difference between a loader and a battering ram. To get some idea of how much it is bent, the top edge of that frame section did start out as a straight line. The whole area where the paint is flaked off has been bent. I would be concerned about related damage to the rest of the outfit. Is the front axle OK? other tractor housings? loader main frame attachment to the tractor?
If those other aspects check out OK, I'd consider doing some repair on the loader. I'd probably put some pull on the frame to try to stretch it back towards the original shape. While stretching, go after the bulged sides to get them flattened back out. I'd stop when the bulges are gone, even though it won't be fully straightened. Try to get it so both sides are the same length. Then weld on some fish plate to each side of both arms. The fish plate should cover the bent area and some beyond.
After doing that, the loader would probably be usable for a long time. You would just need to be a little extra gentle with it. You would probably need to do this repair yourself. If you can't do it yourself, it is unlikely to be worth it if you have to hire it done.
EDIT: I see Janicholson suggested cutting out some of the damaged material. That might work better than my suggestion of trying to push the bulges back in.
This post was edited by Jim Becker at 08:25:40 12/06/12.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
