Re: Industrial A brake replacement
Posted by gene bender on December 06, 2012 at 17:45:22 from (207.177.56.85):
In Reply to: Industrial A brake replacement posted by Dale Ross on December 06, 2012 at 11:56:41:
Itds been covered many times. Job will go better if you have a cherry picker to remove the finals. Blocking the tractor is most important. I remove the centers and tires together so the final is easier to remove. You will want to replace both seals on each side while its apart. Thr final drive comes of in one piece. You will need to remove the brake drums to remove the diff shaft so the outer seals can be replaced. The diff shaft will come out after removing the brake drums and come out by removing the 4 bolted plate on the final drives.
