HELP- Removing lift cover from 584
Posted by warrenwoodrow on December 06, 2012 at 19:02:11 from (65.7.0.49):
After removing everything necessary I am now ready to remove lift housing. Question - Do I have too remove the auxillary valve located on right hand side and bolted to side of lift cover. I am hopeful that I do not as it looks complicated . I have disconnected the hose fittings and hope to leave it on when I pull the top of the lift housing.
