Farmall C (pics)
Posted by Paul Gi. on December 06, 2012 at 20:29:06 from (74.32.245.169):
third party image
third party image
third party image
Couple of pictures of 3 Farmall C's & Super C that my Dad and I restord. We use the planter to plant sweet corn every year. It has double disk openers on it and also has the check wire spool mounted on the back that is chain driven off the left side brake shaft to roll up the wire. I think it still has original tires and cushion seat. The other C has a two row cultivator and a set of spike toothed shovels behind the rear tires which I assume is to take out the wheel tracks. The super C now has a woods mower on it. The other C has a two bottom plow and longer rear axels compared to the other C's we have. Also have a axel mount sickel bar mower. We restored these a couple years ago but use them all through out the year.
