Re: Got the super h running
Posted by Huskers86 on December 07, 2012 at 06:53:12 from (64.147.35.58):
In Reply to: Got the super h running posted by Huskers86 on December 05, 2012 at 19:57:25:
I've built a lot of race engines and car/truck engines and we would run them around 2500 rpm for an hour and then put cardboard in front of the radiator to build the heat up to 230 degrees and then shut them down and walk away untill the next morning. Basic theory of putting a heat cycle through it and we always had good luck. I'm just starting to rebuild tractors so it's sorta different but the main thing as you've all said is to get those rings seated.
