Re: 1086 Hydrualics
Posted by The tractor vet on December 07, 2012 at 09:55:25 from (76.212.227.196):
In Reply to: 1086 Hydrualics posted by CumminsMan on December 07, 2012 at 09:05:25:
Your really limited on the old system as stock they only made 12 GPM when they were in good shape , yes you can install a bigger GPM pump but the filter system was not designed for much more then 14 . Either Allied or Ag Parts had a add on filter extension where you mounted a extra housing where the org. filter was and ya stacked two filters on top of each other. and it stuck way out the side of the tractor . Myself i did not care for it as all i could see is it getting knocked off with the way guys treat there tractors around here . Does it work , Don't know and i ain't ah going to say one way or other.
