Re: WooHoo! H hydraulics work!!!
Posted by CNKS on December 07, 2012 at 15:10:56 from (216.144.104.128):
In Reply to: Re: WooHoo! H hydraulics work!!! posted by MisterT on December 07, 2012 at 07:37:55:
Probably cover to cover, detergent and hytran were not sold when the tractor was built--1947. I currently have the latest version of the Super M manual, which covers both the belly pump and live hydraulics. It does not mention detergent vs non detergent for the belly pump, just to use premium quality engine oil. At some point in the 50's our dealer started selling detergent oil, nothing was made of that and at that time no one worried about foaming -- as I said it was not a problem for our H. If you have a manual about the belly pump that says not to use detergent, give me a quotation out of it and I will withdraw my statement.
This post was edited by CNKS at 17:25:42 12/07/12.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
