Re: farmall H steering
Posted by FBH44 on December 08, 2012 at 01:41:47 from (64.85.216.213):
In Reply to: farmall H steering posted by buffy1 on December 07, 2012 at 19:32:33:
Those big nuts alwsays get chewed up. No problem, I finally ground two big flats on mine, and use a Cerscent wrench. Once you get inside there, it may be the worm gear worn, it may be no seal in t he bottom of the housing letting all the oil drain out, it may be the sector geaar. I had lots of these problems, , the latest was the sectror gear nut needed tightening down. Keep at it, yuou"ll get it.
