There are quite a few posts in the archives, and can be found by searching this site. However, the thumbnail is: take all fittings off the tank. treat with muriatic acid (using all safety measures). Do the "triple rinse" with water. Last rinse with acetone. Dry thoroughly. Use your favorite tank coating, I prefer Caswell, but there are others. After acid treatment it is very important to coat the inside of the tank to prevent rust.
Or you can send the tank out to places that specialize in tank cleaning/coating.
If you don't want to go through all that, at least remove the tank and rinse and invert the tank multiple times using acetone, gasoline, diesel, etc. This will get most of the "crap" out of the tank. If there is scaley rust in it, put a small handful of drywall screws in, a little gasoline, and close up the openings. Agitate the tank the best way you can, so that the drywall screws loosen all the scale. Then do the multiple rinse steps. You still need to consider sealing the inside of the tank to stop/prevent future rust.
Others will post with their prefered methods. Bottom line, tank the tank off the tractor and get the crud out, and rinse.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
