I use these type of filters on everything. Yes I use to have the same problem you are discussing. Some filters are not gravity flow they need some pressure, but even those that are gravity flow, the volume of gas needed on a tractor is much more than a lawnmower so some will cause a vacumn. Be sure to use a large enough filter to allow enough fuel through it. But in all cases I found if you will angle the filter so the inlet is higher than the outlet than it wont airlock. The angle allows the air to go back to the tank when it the gas is first turned on and the entire filter will fill with gas. My 2 cents....
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
