Re: Steering IH 464 -problem?
Posted by jimb2 on December 08, 2012 at 06:36:53 from (174.114.182.155):
In Reply to: Steering IH 464 -problem? posted by hayray on December 08, 2012 at 05:36:02:
Hi Ray, is this tractor new to you? Does it have a front end loader? Simple ? first, did someone adjust the width of the front axle without adjusting the steering drag links? Lastly there is a bracket up under the front axle mount that holds the steering cylinder in place. There is a couple grease fittings on the bracket that most operators forget to lube.
My brother manage to break this bracket on his 495 with a 2250 FEL on it.
When the steering knuckle bushings of front wheel bearing are shot, the first indication is the front tire starts rubbing on the front axle support. There is also a woodruff key on each steering knuckle that could have sheared but have never seen that problem.
Good luck
JimB
